HP EliteBook 850 G7 RAM Replacement
  1. HP EliteBook 850 G7 RAM Replacement, RAM: step 1, image 1 of 2 HP EliteBook 850 G7 RAM Replacement, RAM: step 1, image 2 of 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 RAM Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 RAM Replacement: step 2, image 2 of 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 RAM Replacement: step 3, image 1 of 3 HP EliteBook 850 G7 RAM Replacement: step 3, image 2 of 3 HP EliteBook 850 G7 RAM Replacement: step 3, image 3 of 3
    • Lift directly up on the marked tab to remove the shielding
    • The RAM is now exposed.
    • When reassembling make sure to realign the sides of the shielding with the clips on the motherboard
    • The new RAM can be inserted and clipped down as shown.
    • For reference the 850 G7 uses DDR4 SODIMMs
Caleb Pierce
230 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 9
All Time: 9
