HP EliteBook 850 G7 RTC Battery Replacement
Caleb Pierce
Caleb Pierce
Last updated on March 10, 2025
10 minutes
Easy
Community-Contributed Guide
  1. HP EliteBook 850 G7 RTC Battery Replacement, RTC Battery: step 1, image 1 of 2 HP EliteBook 850 G7 RTC Battery Replacement, RTC Battery: step 1, image 2 of 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 RTC Battery Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 RTC Battery Replacement: step 2, image 2 of 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 RTC Battery Replacement: step 3, image 1 of 2 HP EliteBook 850 G7 RTC Battery Replacement: step 3, image 2 of 2
    • Unscrew the marked screw
    • Pull the SSD out in the marked direction
  4. HP EliteBook 850 G7 RTC Battery Replacement: step 4, image 1 of 1
    • Unplug the marked cable and the RTC Battery can be pulled out
Caleb Pierce
554 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 10
All Time: 10
