HP EliteBook 850 G7 SSD Replacement
  1. HP EliteBook 850 G7 SSD Replacement, SSD: step 1, image 1 of 2 HP EliteBook 850 G7 SSD Replacement, SSD: step 1, image 2 of 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 SSD Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 SSD Replacement: step 2, image 2 of 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 SSD Replacement: step 3, image 1 of 2 HP EliteBook 850 G7 SSD Replacement: step 3, image 2 of 2
    • Unscrew the marked screw
    • Pull the SSD out in the marked direction
    • It can be replaced with most NVME 2280 SSDs
Caleb Pierce
230 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 8
All Time: 8
