Introduction
Hello, this guide will help you replace the memory in a HP EliteBook 8560w.
Keep in mind that this model has two pairs of memory: one pair below the back panel and another below the keyboard. We’ll describe the steps for both.
Usually, a computer’s memory needs to be replaced when a message of “not enough memory” pops up in your screen. However, check out our troubleshooting page to see if your problem falls into a different category.
Please follow instructions as they appear.
Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
Pull both metal parts away from memory pair. Lift memory pair and it will come out.
