HP EliteBook Folio 1020 G1 Battery Replacement
  1. HP EliteBook Folio 1020 G1 Battery Replacement, Lower Case: step 1, image 1 of 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Battery Replacement: step 2, image 1 of 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Battery Replacement, Battery: step 3, image 1 of 2 HP EliteBook Folio 1020 G1 Battery Replacement, Battery: step 3, image 2 of 2
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
Drew Borden
606 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 42
All Time: 845
