HP EliteBook Folio 1040 G1 Battery Replacement
  1. HP EliteBook Folio 1040 G1 Battery Replacement, Battery: step 1, image 1 of 3 HP EliteBook Folio 1040 G1 Battery Replacement, Battery: step 1, image 2 of 3 HP EliteBook Folio 1040 G1 Battery Replacement, Battery: step 1, image 3 of 3
    • Power the laptop off before beginning.
    • Flip the laptop over so the model sticker faces up.
    • Remove the eleven 4 mm screws from the back cover of the laptop using a Torx TR9 screwdriver.
  2. HP EliteBook Folio 1040 G1 Battery Replacement: step 2, image 1 of 2 HP EliteBook Folio 1040 G1 Battery Replacement: step 2, image 2 of 2
    • Starting from the hinge, lift the back cover off of the laptop.
  3. HP EliteBook Folio 1040 G1 Battery Replacement: step 3, image 1 of 3 HP EliteBook Folio 1040 G1 Battery Replacement: step 3, image 2 of 3 HP EliteBook Folio 1040 G1 Battery Replacement: step 3, image 3 of 3
    • Remove the six 3 mm screws securing the battery to the laptop using a Phillips #0 screwdriver.
  4. HP EliteBook Folio 1040 G1 Battery Replacement: step 4, image 1 of 3 HP EliteBook Folio 1040 G1 Battery Replacement: step 4, image 2 of 3 HP EliteBook Folio 1040 G1 Battery Replacement: step 4, image 3 of 3
    • While gently tugging on the battery's connector, disconnect it from its port.
    • Remove the battery from the device.
Andrew Gebo
210 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 42
All Time: 1,513
