HP EliteBook x360 1030 G3 Fan Replacement
  1. HP EliteBook x360 1030 G3 Fan Replacement, Bottom Cover: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Fan Replacement: step 2, image 1 of 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Fan Replacement, Fan: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  4. HP EliteBook x360 1030 G3 Fan Replacement: step 4, image 1 of 3 HP EliteBook x360 1030 G3 Fan Replacement: step 4, image 2 of 3 HP EliteBook x360 1030 G3 Fan Replacement: step 4, image 3 of 3
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Fan Replacement: step 5, image 1 of 2 HP EliteBook x360 1030 G3 Fan Replacement: step 5, image 2 of 2
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
4 other people completed this guide.
Pablo Arriola
504 Reputation
3 Guides authored
Cal Poly, Team S2-G9, Maness Spring 2019 Member of Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 72
All Time: 4,406
