HP EliteBook x360 1030 G3 Solid State Drive Replacement
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: step 2, image 1 of 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: step 3, image 1 of 2 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: step 3, image 2 of 2
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: step 4, image 1 of 1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: step 5, image 1 of 1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
3 other people completed this guide.
Pablo Arriola
504 Reputation
3 Guides authored
Cal Poly, Team S2-G9, Maness Spring 2019 Member of Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Members
16 Guides authored
3 Comments
Which SSD is compatible with this computer?
Trinayaan Hariharan - Reply
Very nice its clear
Fuad Gugsa - Reply
J'ai un problème de son
Sallpape - Reply
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 126
All Time: 5,909
