HP EliteBook x360 830 G5 Touchpad Replacement
  1. HP EliteBook x360 830 G5 Touchpad Replacement, Back Cover: step 1, image 1 of 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Touchpad Replacement: step 2, image 1 of 2 HP EliteBook x360 830 G5 Touchpad Replacement: step 2, image 2 of 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Touchpad Replacement: step 3, image 1 of 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Touchpad Replacement, Touchpad: step 4, image 1 of 1
    • Use a PH000 screw-bit and a screwdriver and remove the six 2 mm screws securing the touch pad bracket.
    • Remove the touch pad.
One Comment
не подробная инструкция. при снятии на данной модели возникает куча косяков, которые могу привести к порче оборудования
Vladislav Orlov - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 222
