HP EliteBook x360 830 G5 Wireless LAN Module Replacement
  1. HP EliteBook x360 830 G5 Wireless LAN Module Replacement, Back Cover: step 1, image 1 of 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Wireless LAN Module Replacement: step 2, image 1 of 2 HP EliteBook x360 830 G5 Wireless LAN Module Replacement: step 2, image 2 of 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Wireless LAN Module Replacement: step 3, image 1 of 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Wireless LAN Module Replacement, Wireless LAN Module: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the coaxial antenna cables from the LAN module with a small pair of tweezers.
  5. HP EliteBook x360 830 G5 Wireless LAN Module Replacement: step 5, image 1 of 1
    • With the Phillips #1 screwdriver, loosen the single screw attaching the LAN module to the board.
  6. HP EliteBook x360 830 G5 Wireless LAN Module Replacement: step 6, image 1 of 1
    • Pull the Wi-Fi card out.
Ashia Lewis
246 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 300
