HP EliteBook x360 830 G6 Battery Replacement
  1. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the back cover: step 1, image 1 of 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Battery Replacement, Release the clips: step 2, image 1 of 2 HP EliteBook x360 830 G6 Battery Replacement, Release the clips: step 2, image 2 of 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: step 3, image 1 of 2 HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: step 3, image 2 of 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: step 4, image 1 of 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: step 4, image 2 of 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: step 4, image 3 of 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: step 5, image 1 of 3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: step 5, image 2 of 3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the battery: step 6, image 1 of 1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: step 7, image 1 of 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: step 7, image 2 of 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: step 7, image 3 of 3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
69,494 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 103
All Time: 2,023
