HP ElitePad 900 Battery Replacement
  1. HP ElitePad 900 Battery Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Battery Replacement: step 2, image 1 of 2 HP ElitePad 900 Battery Replacement: step 2, image 2 of 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Battery Replacement: step 3, image 1 of 2 HP ElitePad 900 Battery Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the six 2.2mm Phillips #000 screws securing the battery to the device.
  5. HP ElitePad 900 Battery Replacement: step 5, image 1 of 1
    • Disconnect and move the wires out of the way.
  6. HP ElitePad 900 Battery Replacement: step 6, image 1 of 2 HP ElitePad 900 Battery Replacement: step 6, image 2 of 2
    • Lift cover.
  7. HP ElitePad 900 Battery Replacement: step 7, image 1 of 2 HP ElitePad 900 Battery Replacement: step 7, image 2 of 2
    • Slide out the battery.
13 other people completed this guide.
Kyle Marques
889 Reputation
6 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2015 Member of USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Members
6 Guides authored
2 Comments
Great Job took 10 min from start to finish!
Dan Goo - Reply
One way to remove screen assembly without a suction cup is to use a piece of duct tape folded onto to itself leaving a small amount of the adhesive portion exposed. This creates a little handle. You can then stick it to assembly and lift it out easily.
Matt Brunk - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 12,258
