HP ElitePad 900 Front Panel Assembly Replacement
  1. HP ElitePad 900 Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Front Panel Assembly Replacement: step 2, image 1 of 2 HP ElitePad 900 Front Panel Assembly Replacement: step 2, image 2 of 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Front Panel Assembly Replacement: step 3, image 1 of 2 HP ElitePad 900 Front Panel Assembly Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
Kyle Marques
889 Reputation
6 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2015 Member of USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,471
