HP ElitePad 900 Speakers Replacement
  1. HP ElitePad 900 Speakers Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Speakers Replacement: step 2, image 1 of 2 HP ElitePad 900 Speakers Replacement: step 2, image 2 of 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Speakers Replacement: step 3, image 1 of 2 HP ElitePad 900 Speakers Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Speakers Replacement, Speakers: step 4, image 1 of 3 HP ElitePad 900 Speakers Replacement, Speakers: step 4, image 2 of 3 HP ElitePad 900 Speakers Replacement, Speakers: step 4, image 3 of 3
    • Remove the eight 2.4mm Phillips #000 screws.
  5. HP ElitePad 900 Speakers Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Gently use tweezers to disconnect the indicator wire.
  6. HP ElitePad 900 Speakers Replacement: step 6, image 1 of 3 HP ElitePad 900 Speakers Replacement: step 6, image 2 of 3 HP ElitePad 900 Speakers Replacement: step 6, image 3 of 3
    • Lift the charging port over the left speaker.
  7. HP ElitePad 900 Speakers Replacement: step 7, image 1 of 3 HP ElitePad 900 Speakers Replacement: step 7, image 2 of 3 HP ElitePad 900 Speakers Replacement: step 7, image 3 of 3
    • Slightly lift the green PCB to slide out the right speaker.
    • Replace the speakers.
Kyle Marques
889 Reputation
6 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2015 Member of USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 959
