HP ElitePad 900 Volume Control Buttons Replacement
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: step 2, image 1 of 2 HP ElitePad 900 Volume Control Buttons Replacement: step 2, image 2 of 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: step 3, image 1 of 2 HP ElitePad 900 Volume Control Buttons Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: step 4, image 1 of 3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: step 4, image 2 of 3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: step 4, image 3 of 3
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
Kyle Marques
889 Reputation
6 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2015 Member of USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 675
