HP Elitebook 2740p Hard Drive Replacement
  1. HP Elitebook 2740p Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Place the laptop face down in front of you.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
    • Remove the back panel.
  2. HP Elitebook 2740p Hard Drive Replacement: step 2, image 1 of 3 HP Elitebook 2740p Hard Drive Replacement: step 2, image 2 of 3 HP Elitebook 2740p Hard Drive Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws from the small metal HDD bracket.
    • Lift up on the small bracket and pull it off.
  3. HP Elitebook 2740p Hard Drive Replacement: step 3, image 1 of 3 HP Elitebook 2740p Hard Drive Replacement: step 3, image 2 of 3 HP Elitebook 2740p Hard Drive Replacement: step 3, image 3 of 3
    • Pull out the hard drive and the small rubber sleigh that holds it.
    • Pull the rubber sleigh off of the hard drive.
6 other people completed this guide.
Cameron Whittle
467 Reputation
2 Guides authored
One Comment
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/165266235415
jacques_06
jacques_06 - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 6,237
