HP Elitebook 820 G1 Battery Replacement
  1. HP Elitebook 820 G1 Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Battery Replacement: step 2, image 1 of 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Battery Replacement: step 3, image 1 of 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Battery Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the battery.
Eugenia Lara Martinez
190 Reputation
1 Guide authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 75
All Time: 11,560
