HP Elitebook 820 G1 Hard Drive Replacement
  1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Hard Drive Replacement: step 3, image 1 of 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Hard Drive Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Remove the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the hard drive casing.
    • Unscrew the four 8mm Philips screws holding the hard drive.
  7. HP Elitebook 820 G1 Hard Drive Replacement: step 7, image 1 of 1
    • Remove the hard drive from the casing and replace it.
3 other people completed this guide.
Alberto Carlos Perez
365 Reputation
2 Guides authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 3,838
