HP Elitebook 820 G1 Keyboard Replacement
Lauren Vance
Lauren Vance and 2 other contributors
Last updated on December 4, 2019
5 minutes
Easy
Introduction
Go to step 1
This guide demonstrates how to safely remove and replace a damaged or malfunctioning keyboard. Following these steps should ensure a simple replacement for a keyboard that has experienced a spill, is missing keys, or otherwise does not function correctly.
Tools
Show more…
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: step 2, image 1 of 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: step 3, image 1 of 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: step 6, image 1 of 1
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: step 7, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 3 of 3
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: step 8, image 1 of 1
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: step 9, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 3 of 3
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: step 10, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 3 of 3
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: step 11, image 1 of 1
    • Remove the keyboard from the housing.
5 other people completed this guide.
Lauren Vance
415 Reputation
2 Guides authored
IUPUI, Team S1-G2, Harley Fall 2018 Member of IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
2 Members
4 Guides authored
One Comment
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 41
All Time: 11,544
