HP Elitebook 820 G2 Hard Disk Drive Replacement
Mackenzie Marcinek
Mackenzie Marcinek and 4 other contributors
Last updated on November 16, 2022
10 minutes
Easy
Introduction
Go to step 1
The hard drive is the device that holds all of your saved data, such as your pictures, documents, etc. When your computer no longer boots up, the hard drive could be to blame. If the hard drive is the problem your having, this guide is will show you how to replace it.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. HP Elitebook 820 G2 Hard Disk Drive Replacement, Back Panel: step 1, image 1 of 2 HP Elitebook 820 G2 Hard Disk Drive Replacement, Back Panel: step 1, image 2 of 2
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
  2. HP Elitebook 820 G2 Hard Disk Drive Replacement: step 2, image 1 of 2 HP Elitebook 820 G2 Hard Disk Drive Replacement: step 2, image 2 of 2
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
  3. HP Elitebook 820 G2 Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 1 of 1
    • The hard drive is found on the bottom right under the back panel.
  4. HP Elitebook 820 G2 Hard Disk Drive Replacement: step 4, image 1 of 2 HP Elitebook 820 G2 Hard Disk Drive Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the four 2 mm screws that secure the hard drive.
  5. HP Elitebook 820 G2 Hard Disk Drive Replacement: step 5, image 1 of 2 HP Elitebook 820 G2 Hard Disk Drive Replacement: step 5, image 2 of 2
    • Pull the tab at the top of the hard drive.
    • Lift up and remove the hard drive.
0 Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 50
All Time: 4,727
