HP Elitebook 840 G7 M.2 NVMe SSD Replacement
Pedro Ramos Espinoza
Pedro Ramos Espinoza and 3 other contributors
Last updated on March 20, 2025
10 minutes
Very easy
Community-Contributed Guide
Introduction
Go to step 1
Use this guide when replacing the storage drive on a HP Elitebook 840 G7.
Storage drive is used to store data, files, and software programs that run on the computer.
Consider upgrading your storage drive if the current one is full or broken. A failing storage drive signs include: Failure to boot, slow performance, and file corruption.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. HP Elitebook 840 G7 M.2 NVMe SSD Replacement, M.2 NVMe SSD: step 1, image 1 of 1
    • Turn the laptop on its back
  2. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 2, image 1 of 1
    • Use your Phillips # 1 screwdriver and remove the five 1.2mm screws from the back cover of the laptop
  3. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 1 of 3 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 2 of 3 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 3 of 3
    • Removing the back cover to expose the hardware
    • Locate the M.2 storage stick and remove the 1.2 mm screw with a Phillips # 1 screwdriver
  4. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 4, image 1 of 2 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 4, image 2 of 2
    • Grab with M.2 storage with your hand and pull away to remove
895 Reputation
4 Guides authored
Gateway, Team 1-1, Pee Spring 2022 Member of Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Members
12 Guides authored
One Comment
Hi, it would be awesome if max length of drive is listed under "parts"
Jacob Ljungström - Reply
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 158
All Time: 3,389
