HP Elitebook 840 G7 M.2 NVMe SSD Replacement
  1. HP Elitebook 840 G7 M.2 NVMe SSD Replacement, M.2 NVMe SSD: step 1, image 1 of 1
    • Turn the laptop on its back
  2. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 2, image 1 of 1
    • Use your Phillips # 1 screwdriver and remove the five 1.2mm screws from the back cover of the laptop
  3. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 1 of 3 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 2 of 3 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 3, image 3 of 3
    • Removing the back cover to expose the hardware
    • Locate the M.2 storage stick and remove the 1.2 mm screw with a Phillips # 1 screwdriver
  4. HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 4, image 1 of 2 HP Elitebook 840 G7 M.2 NVMe SSD Replacement: step 4, image 2 of 2
    • Grab with M.2 storage with your hand and pull away to remove
Pedro Ramos Espinoza
895 Reputation
4 Guides authored
Gateway, Team 1-1, Pee Spring 2022 Member of Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Members
12 Guides authored
One Comment
Hi, it would be awesome if max length of drive is listed under "parts"
Jacob Ljungström - Reply
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 173
All Time: 3,423
