HP Elitebook 8460p Optical Drive Replacement
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: step 1, image 1 of 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: step 2, image 1 of 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: step 3, image 1 of 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: step 4, image 1 of 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 3 of 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: step 6, image 1 of 2 HP Elitebook 8460p Optical Drive Replacement: step 6, image 2 of 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: step 7, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement: step 7, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement: step 7, image 3 of 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: step 8, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement: step 8, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement: step 8, image 3 of 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,059
