HP Elitebook 8460p RAM (Random Access Memory) Replacement
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: step 1, image 1 of 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: step 2, image 1 of 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: step 3, image 1 of 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: step 4, image 1 of 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): step 5, image 1 of 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): step 5, image 2 of 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): step 5, image 3 of 3
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: step 6, image 1 of 2 HP Elitebook 8460p RAM (Random Access Memory) Replacement: step 6, image 2 of 2
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
4 other people completed this guide.
1 Guide Comment
Great job thanks
Charles Tighe - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 49
All Time: 2,490
