HP Elitebook Folio 9470m Keyboard Replacement
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: step 2, image 1 of 2 HP Elitebook Folio 9470m Keyboard Replacement: step 2, image 2 of 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 3 of 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 3 of 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: step 5, image 1 of 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 3 of 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: step 7, image 1 of 2 HP Elitebook Folio 9470m Keyboard Replacement: step 7, image 2 of 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
Kenneth Bowers
1,381 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 5,430
