HP Elitebook Folio 9470m RAM Replacement
  1. HP Elitebook Folio 9470m RAM Replacement, RAM: step 1, image 1 of 1
    • Remove battery using this guide here.
  2. HP Elitebook Folio 9470m RAM Replacement: step 2, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 2, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 2, image 3 of 3
    • Unscrew 2 Phillips head screws, lift slightly up and out to remove hard drive cover.
  3. HP Elitebook Folio 9470m RAM Replacement: step 3, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 3, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 3, image 3 of 3
    • Remove the three Phillips screws from the back plate. Pull slightly up and out to remove the plate.
    • These screws are also marked with a small RAM icon.
  4. HP Elitebook Folio 9470m RAM Replacement: step 4, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 4, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 4, image 3 of 3
    • Gently push out the small tabs on either side.
    • The RAM should pop up and easily be taken out from there.
7 other people completed this guide.
Kenneth Bowers
1,381 Reputation
7 Guides authored
One Comment
There are 2 black Philips screws more you have to loose, before you can open the back plate. One on the left side (near wifi card), and on right side.
Mikael Salo - Reply
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 103
All Time: 6,154
