HP Elitebook Folio 9470m Trackpad Replacement
  1. HP Elitebook Folio 9470m Trackpad Replacement, Trackpad: step 1, image 1 of 1
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Trackpad Replacement: step 2, image 1 of 1
    • In the center of the laptop slide the black piece back till it turns red indicating it is unlocked and the battery can be removed.
  3. HP Elitebook Folio 9470m Trackpad Replacement: step 3, image 1 of 2 HP Elitebook Folio 9470m Trackpad Replacement: step 3, image 2 of 2
    • Remove the 2 Phillips head screws that attach the cover on the left.
  4. HP Elitebook Folio 9470m Trackpad Replacement: step 4, image 1 of 3 HP Elitebook Folio 9470m Trackpad Replacement: step 4, image 2 of 3 HP Elitebook Folio 9470m Trackpad Replacement: step 4, image 3 of 3
    • Remove the 4 Phillips screws holding the hard drive in place
    • Remove by gently prying and pulling up on the tab and out.
  5. HP Elitebook Folio 9470m Trackpad Replacement: step 5, image 1 of 3 HP Elitebook Folio 9470m Trackpad Replacement: step 5, image 2 of 3 HP Elitebook Folio 9470m Trackpad Replacement: step 5, image 3 of 3
    • Remove the 3 Phillips head screws holding the back plate in.
    • Gently pull up and out to remove plate.
  6. HP Elitebook Folio 9470m Trackpad Replacement: step 6, image 1 of 2 HP Elitebook Folio 9470m Trackpad Replacement: step 6, image 2 of 2
    • Remove all eighteen screws marked M2x3 and M2x5.
    • Remove the remaining four Phillips head screws.
  7. HP Elitebook Folio 9470m Trackpad Replacement: step 7, image 1 of 2 HP Elitebook Folio 9470m Trackpad Replacement: step 7, image 2 of 2
    • Slowly pry and lift the frame up while checking for connected wires and ribbons that may be obstructing it.
  8. HP Elitebook Folio 9470m Trackpad Replacement: step 8, image 1 of 2 HP Elitebook Folio 9470m Trackpad Replacement: step 8, image 2 of 2
    • Detach ribbon wires by gently lifting the grey flap and pulling them out.
    • Do not pull hard on the wires.
    • Push the track pad from the bottom and it should come right out.
Kenneth Bowers
1,381 Reputation
7 Guides authored
One Comment
Please make sure the Track Pad is not "turned off:" (HP Folio has a Track Pad on/off feature by double-tap in upper left hand corner)
1) Double tap the upper left corner of the Track Pad by the Amber LED
2a) If the LED is "On" then the Track Pad is "Off"
2b) If the LED is "Off" then the Track Pad is "On"
nemisonic - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 29
All Time: 3,785
