HP Elitebook x360 1030 G2 Battery Replacement
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: step 2, image 1 of 2 HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: step 2, image 2 of 2
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: step 3, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Max Kletskov
40,307 Reputation
16 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,903 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 111
All Time: 4,288
