HP Elitebook x360 1040 G5 SSD Replacement
  1. HP Elitebook x360 1040 G5 SSD Replacement, Lower Case: step 1, image 1 of 2 HP Elitebook x360 1040 G5 SSD Replacement, Lower Case: step 1, image 2 of 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 SSD Replacement: step 2, image 1 of 2 HP Elitebook x360 1040 G5 SSD Replacement: step 2, image 2 of 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 SSD Replacement, SSD: step 3, image 1 of 3 HP Elitebook x360 1040 G5 SSD Replacement, SSD: step 3, image 2 of 3 HP Elitebook x360 1040 G5 SSD Replacement, SSD: step 3, image 3 of 3
    • Use the Phillips 0 screwdriver to remove the 2mm Phillips screws from the SSD assembly.
    • Gently slide the SSD to the right and pull out to remove it from its position within the motherboard.
3 other people completed this guide.
Corey Agena
833 Reputation
6 Guides authored
Cal Poly, Team S1-G4, Maness Spring 2019 Member of Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 43
All Time: 3,394
