HP Elitebook x360 1040 G5 Speakers Replacement
  1. HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: step 1, image 1 of 2 HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: step 1, image 2 of 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Speakers Replacement: step 2, image 1 of 2 HP Elitebook x360 1040 G5 Speakers Replacement: step 2, image 2 of 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Speakers Replacement, Battery: step 3, image 1 of 2 HP Elitebook x360 1040 G5 Speakers Replacement, Battery: step 3, image 2 of 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Speakers Replacement: step 4, image 1 of 3 HP Elitebook x360 1040 G5 Speakers Replacement: step 4, image 2 of 3 HP Elitebook x360 1040 G5 Speakers Replacement: step 4, image 3 of 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: step 5, image 1 of 2 HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: step 5, image 2 of 2
    • Use the Phillips 0 screwdriver to remove the four 3mm Phillips screws from the speaker assembly.
  6. HP Elitebook x360 1040 G5 Speakers Replacement: step 6, image 1 of 3 HP Elitebook x360 1040 G5 Speakers Replacement: step 6, image 2 of 3 HP Elitebook x360 1040 G5 Speakers Replacement: step 6, image 3 of 3
    • Carefully remove the plug, connecting the speaker assembly to the motherboard on the right hand side, by pulling on either side of its head.
Corey Agena
833 Reputation
6 Guides authored
Cal Poly, Team S1-G4, Maness Spring 2019 Member of Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 538
