HP Elitebook x360 1040 G5 Touchpad Replacement
  1. HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: step 1, image 1 of 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: step 1, image 2 of 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Touchpad Replacement: step 2, image 1 of 2 HP Elitebook x360 1040 G5 Touchpad Replacement: step 2, image 2 of 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: step 3, image 1 of 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: step 3, image 2 of 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Touchpad Replacement: step 4, image 1 of 3 HP Elitebook x360 1040 G5 Touchpad Replacement: step 4, image 2 of 3 HP Elitebook x360 1040 G5 Touchpad Replacement: step 4, image 3 of 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: step 5, image 1 of 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: step 5, image 2 of 2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
  6. HP Elitebook x360 1040 G5 Touchpad Replacement: step 6, image 1 of 3 HP Elitebook x360 1040 G5 Touchpad Replacement: step 6, image 2 of 3 HP Elitebook x360 1040 G5 Touchpad Replacement: step 6, image 3 of 3
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the left hand side.
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the right hand side.
  7. HP Elitebook x360 1040 G5 Touchpad Replacement: step 7, image 1 of 1
    • Gently pull up on the top two corners of the touchpad and remove it from the laptop.
Corey Agena
833 Reputation
6 Guides authored
Cal Poly, Team S1-G4, Maness Spring 2019 Member of Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 696
