HP Envy 15-u001dx Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. HP Envy 15-u001dx Battery Replacement, HP Envy 15-u001dx Disassembly: step 1, image 1 of 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Battery Replacement: step 2, image 1 of 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Battery Replacement: step 3, image 1 of 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Battery Replacement: step 4, image 1 of 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Battery Replacement: step 5, image 1 of 2 HP Envy 15-u001dx Battery Replacement: step 5, image 2 of 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Battery Replacement, Battery: step 6, image 1 of 3 HP Envy 15-u001dx Battery Replacement, Battery: step 6, image 2 of 3 HP Envy 15-u001dx Battery Replacement, Battery: step 6, image 3 of 3
    • Remove the three 3 mm screws from the battery using Phillips #0 screwdriver.
  7. HP Envy 15-u001dx Battery Replacement: step 7, image 1 of 1
    • Use a spudger to gently detach the battery connector.
3 other people completed this guide.
Dakota Presley
885 Reputation
6 Guides authored
USF Tampa, Team 9-4, Lacy Fall 2016 Member of USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,039
