HP Envy 15-u001dx RAM Replacement
  1. HP Envy 15-u001dx RAM Replacement, Motherboard: step 1, image 1 of 3 HP Envy 15-u001dx RAM Replacement, Motherboard: step 1, image 2 of 3 HP Envy 15-u001dx RAM Replacement, Motherboard: step 1, image 3 of 3
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx RAM Replacement: step 2, image 1 of 2 HP Envy 15-u001dx RAM Replacement: step 2, image 2 of 2
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx RAM Replacement: step 3, image 1 of 2 HP Envy 15-u001dx RAM Replacement: step 3, image 2 of 2
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx RAM Replacement: step 4, image 1 of 1
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx RAM Replacement: step 5, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 5, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 5, image 3 of 3
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx RAM Replacement: step 6, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 6, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 6, image 3 of 3
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx RAM Replacement: step 7, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 7, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 7, image 3 of 3
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx RAM Replacement: step 8, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 8, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 8, image 3 of 3
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx RAM Replacement: step 9, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 9, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 9, image 3 of 3
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx RAM Replacement: step 10, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 10, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 10, image 3 of 3
  11. HP Envy 15-u001dx RAM Replacement: step 11, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 11, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 11, image 3 of 3
  12. HP Envy 15-u001dx RAM Replacement: step 12, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 12, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 12, image 3 of 3
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx RAM Replacement: step 13, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 13, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 13, image 3 of 3
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx RAM Replacement: step 14, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 14, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 14, image 3 of 3
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx RAM Replacement: step 15, image 1 of 1
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx RAM Replacement: step 16, image 1 of 1
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx RAM Replacement: step 17, image 1 of 2 HP Envy 15-u001dx RAM Replacement: step 17, image 2 of 2
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx RAM Replacement: step 18, image 1 of 2 HP Envy 15-u001dx RAM Replacement: step 18, image 2 of 2
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx RAM Replacement: step 19, image 1 of 1
    • The disconnected motherboard should look like the indicated photo.
  20. HP Envy 15-u001dx RAM Replacement, RAM: step 20, image 1 of 1
    • Flip the motherboard over after removing it from the chassis. This will allow you to see th RAM itself (the blue rectangles in this picture).
  21. HP Envy 15-u001dx RAM Replacement: step 21, image 1 of 3 HP Envy 15-u001dx RAM Replacement: step 21, image 2 of 3 HP Envy 15-u001dx RAM Replacement: step 21, image 3 of 3
    • Press the metal locks on each side to release the RAM card.
    • The RAM should pop out a little, and can then be removed.
Nathan Browning
373 Reputation
2 Guides authored
IUPUI, Team S1-G1, Henning Fall 2019 Member of IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 21
All Time: 668
