HP Envy 17-3070NR Back Cover Replacement
  1. HP Envy 17-3070NR Back Cover Replacement, Back Cover: step 1, image 1 of 2 HP Envy 17-3070NR Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Back Cover Replacement: step 2, image 1 of 3 HP Envy 17-3070NR Back Cover Replacement: step 2, image 2 of 3 HP Envy 17-3070NR Back Cover Replacement: step 2, image 3 of 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
2 other people completed this guide.
Abby Lentz
586 Reputation
4 Guides authored
Cal Poly, Team 14-8, Amido Spring 2015 Member of Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 5,279
