Introduction
Use this guide to upgrade the RAM of your HP Envy 17-3070NR to boost performance or to replace faulty one if you start getting RAM related blink codes, which are explained in the troubleshooting section.
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Press down on both tabs on either side of the top RAM stick.
The RAM will slightly pop out and you will be able to slide it out of it's cavity.
Repeat the same process for the second stick of RAM if needed.
