HP Envy 17m-ae111dx CPU Fan Replacement
  1. HP Envy 17m-ae111dx CPU Fan Replacement, Back Cover: step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx CPU Fan Replacement: step 2, image 1 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 2, image 2 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 2, image 3 of 3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx CPU Fan Replacement: step 3, image 1 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 3, image 2 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 3, image 3 of 3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx CPU Fan Replacement: step 4, image 1 of 2 HP Envy 17m-ae111dx CPU Fan Replacement: step 4, image 2 of 2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx CPU Fan Replacement: step 5, image 1 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 5, image 2 of 3 HP Envy 17m-ae111dx CPU Fan Replacement: step 5, image 3 of 3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: step 6, image 1 of 3 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: step 6, image 2 of 3 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: step 6, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the three 5.5mm screws that secure the fan.
    • Unplug the wire that is connected to the fan and move the wires so they are out of the way of the fan.
    • Remove the tape off of the fan that is holding the wires in place against the fan.
  7. HP Envy 17m-ae111dx CPU Fan Replacement: step 7, image 1 of 2 HP Envy 17m-ae111dx CPU Fan Replacement: step 7, image 2 of 2
    • Remove the fan from the laptop, ensuring the wires are properly disconnected.
3 other people completed this guide.
One Comment
Excellent video...extremely helpful...thank you
Frank D - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,874
