HP Envy 4-1030us Battery Replacement
Christopher Luna
Christopher Luna and 2 other contributors
Last updated on January 4, 2018
10 minutes
Moderate
Introduction
Go to step 1
This replacement guide will show in-depth step by step tasks to easily remove and replace the battery from the HP Envy 4-1030us. This guide is used in case of a faulty battery, or something caused it to break.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Tools
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us Battery Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: step 2, image 1 of 2 HP Envy 4-1030us Battery Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: step 3, image 1 of 2 HP Envy 4-1030us Battery Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: step 4, image 1 of 2 HP Envy 4-1030us Battery Replacement: step 4, image 2 of 2
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: step 5, image 1 of 2 HP Envy 4-1030us Battery Replacement: step 5, image 2 of 2
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
2 other people completed this guide.
Christopher Luna
700 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 999
