HP Envy 4-1030us CPU Fan Replacement
  1. HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us CPU Fan Replacement: step 2, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us CPU Fan Replacement, CPU Fan: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver unscrew the two 4.2mm screws fastening the CPU fan to the heatsink and motherboard.
  4. HP Envy 4-1030us CPU Fan Replacement: step 4, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement: step 4, image 2 of 2
    • Carefully lift up the CPU fan to gain better access to the fan cable.
    • Disconnect the fan cable by pulling the cable away from the connector and remove the fan from the device.
Christopher Luna
700 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 414
