HP Envy 4-1030us Wireless Card Replacement
  1. HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Wireless Card Replacement: step 2, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
    • After removing the bottom cover, the wireless card is accessible toward the rear of the system.
    • The wireless card may be underneath a piece or layer of black protective electrical tape. Carefully peel back the tape to access the card.
  4. HP Envy 4-1030us Wireless Card Replacement: step 4, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement: step 4, image 2 of 2
    • Disconnect the wires from the wireless card by lifting them up from the metal studs they are set on.
    • The wires are not screwed onto the studs, but may still require some wiggling or twisting to help them come off.
  5. HP Envy 4-1030us Wireless Card Replacement: step 5, image 1 of 1
    • Using the Phillips #0 screwdriver unscrew the single 2.5mm screw holding the card to the motherboard.
  6. HP Envy 4-1030us Wireless Card Replacement: step 6, image 1 of 1
    • Slide the card out of it's connector.
    • After removing the screw, the card will lift at an angle in its connector.
Christopher Luna
700 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 254
