HP Envy 4-1105dx  Hard Drive Replacement
KC Armstrong
KC Armstrong and one other contributor
Last updated on January 4, 2018
25 minutes
Moderate
Introduction
Go to step 1
Use this guide to replace your hard drive. If you have determined that your hard drive is not working or if you want a hard drive with more storage space, it may be time to replace it.
Tools
Show more…
  1. HP Envy 4-1105dx  Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx  Hard Drive Replacement: step 2, image 1 of 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx  Hard Drive Replacement: step 3, image 1 of 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx  Hard Drive Replacement: step 4, image 1 of 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx  Hard Drive Replacement: step 5, image 1 of 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx  Hard Drive Replacement: step 6, image 1 of 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx  Hard Drive Replacement: step 7, image 1 of 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx  Hard Drive Replacement: step 8, image 1 of 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
  9. HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: step 9, image 1 of 2 HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: step 9, image 2 of 2
    • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
    • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
  10. HP Envy 4-1105dx  Hard Drive Replacement: step 10, image 1 of 3 HP Envy 4-1105dx  Hard Drive Replacement: step 10, image 2 of 3 HP Envy 4-1105dx  Hard Drive Replacement: step 10, image 3 of 3
    • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
    • Once it is loose, pull the hard drive out of the socket.
    • Remove the hard drive from the device.
  11. HP Envy 4-1105dx  Hard Drive Replacement: step 11, image 1 of 3 HP Envy 4-1105dx  Hard Drive Replacement: step 11, image 2 of 3 HP Envy 4-1105dx  Hard Drive Replacement: step 11, image 3 of 3
    • Pull out the hard drive cable from the hard drive, and set it aside.
    • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
  12. HP Envy 4-1105dx  Hard Drive Replacement: step 12, image 1 of 1
    • Remove the hard drive from the hard drive case.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 918
