HP Envy 5660 Printhead Replacement
  1. HP Envy 5660 Printhead Replacement, Printhead: step 1, image 1 of 1
    • Open the printer so that the underside of the scanner is showing.
  2. HP Envy 5660 Printhead Replacement: step 2, image 1 of 1
    • Unscrew the black 11.5 mm screw closest to the front right corner using a T10 screw bit.
  3. HP Envy 5660 Printhead Replacement: step 3, image 1 of 1
    • Remove right side of the printer using a plastic opening tool or metal spudger.
  4. HP Envy 5660 Printhead Replacement: step 4, image 1 of 1
    • Remove spring from the side of the print head rail using a metal spudger.
  5. HP Envy 5660 Printhead Replacement: step 5, image 1 of 2 HP Envy 5660 Printhead Replacement: step 5, image 2 of 2
    • Push the metal rail the print head rests on inwards to remove it from its bearings.
  6. HP Envy 5660 Printhead Replacement: step 6, image 1 of 1
    • Remove the belt from the back of the print head using a metal spudger.
  7. HP Envy 5660 Printhead Replacement: step 7, image 1 of 1
    • Remove the print head from the metal rail by sliding it off the rail.
Ryan Steakley
781 Reputation
5 Guides authored
Cal Poly, Team S1-G6, Livingston Winter 2018 Member of Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Members
10 Guides authored
One Comment
I wouldn't recommend this guide to anyone without prior experience as it's non-thorough and missing many steps. Started with a clogged printhead; finished with a torn ribbon cable and a couple other new damages.
Ryan Steakley's Dad - Reply
Past 24 Hours: 7
Past 7 Days: 44
Past 30 Days: 155
All Time: 5,617
