HP Envy 700-030qe Power Supply Replacement
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: step 1, image 1 of 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: step 1, image 2 of 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: step 1, image 3 of 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: step 2, image 1 of 2 HP Envy 700-030qe Power Supply Replacement: step 2, image 2 of 2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: step 3, image 1 of 1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: step 4, image 1 of 2 HP Envy 700-030qe Power Supply Replacement: step 4, image 2 of 2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: step 5, image 1 of 1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: step 6, image 1 of 1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: step 7, image 1 of 1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: step 8, image 1 of 1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: step 9, image 1 of 1
    • Unplug the power cable going to the fan by pulling straight up.
3 other people completed this guide.
Yoav Rosenberg
369 Reputation
2 Guides authored
Cal Poly, Team 5-9, Maness Fall 2015 Member of Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 4,525
