HP Envy 700-030qe RAM Replacement
  1. HP Envy 700-030qe RAM Replacement, RAM: step 1, image 1 of 3 HP Envy 700-030qe RAM Replacement, RAM: step 1, image 2 of 3 HP Envy 700-030qe RAM Replacement, RAM: step 1, image 3 of 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe RAM Replacement: step 2, image 1 of 2 HP Envy 700-030qe RAM Replacement: step 2, image 2 of 2
    • You can now slide off the side panel of the desktop.
    • You should now have an opening on the side of your computer as shown in the second picture.
    • The location of the RAM is highlighted in red.
  3. HP Envy 700-030qe RAM Replacement: step 3, image 1 of 2 HP Envy 700-030qe RAM Replacement: step 3, image 2 of 2
    • Undo the clips on each end of the chip as shown in the second picture.
    • Then you may carefully remove the RAM chips by pulling them out by their the ends.
    • Make sure you pull the chips out by the ends and not grabbing the entire thing. This may damage the chips.
    • Remember the slots that you take the RAM chips from. You must put the two replacement chips in the same slots.
Sam Wheeler
228 Reputation
1 Guide authored
Cal Poly, Team 5-9, Maness Fall 2015 Member of Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 960
