HP Envy 7640 Screen Replacement
  1. HP Envy 7640 Screen Replacement, Screen: step 1, image 1 of 3 HP Envy 7640 Screen Replacement, Screen: step 1, image 2 of 3 HP Envy 7640 Screen Replacement, Screen: step 1, image 3 of 3
    • Open the printer by pushing upwards against the plastic tabs on the printer body's sides.
    • Remove the opening assist by pushing it toward the front of the printer with a nylon spudger.
    • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
  2. HP Envy 7640 Screen Replacement: step 2, image 1 of 3 HP Envy 7640 Screen Replacement: step 2, image 2 of 3 HP Envy 7640 Screen Replacement: step 2, image 3 of 3
    • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to remove the two 12 mm screws that hold the screen manifold to the printer.
    • Push with minimal force to the right to dislodge the manifold from the printer body.
    • Lift the panel up and turn it over to reveal the green micro-controller board underneath.
  3. HP Envy 7640 Screen Replacement: step 3, image 1 of 2 HP Envy 7640 Screen Replacement: step 3, image 2 of 2
    • Undo the two connectors by gently pulling them away from the board.
    • Remove the last connector by flipping the tab up and pulling away from the board while also pulling left.
    • Remove the five 6.5 mm screws from the board using the T6 Torx screwdriver.
  4. HP Envy 7640 Screen Replacement: step 4, image 1 of 1
    • Insert the plastic opening tool into the space between the green board and the printer manifold and push downwards to dislodge the green board.
  5. HP Envy 7640 Screen Replacement: step 5, image 1 of 3 HP Envy 7640 Screen Replacement: step 5, image 2 of 3 HP Envy 7640 Screen Replacement: step 5, image 3 of 3
    • Peel back the tape that holds the screen in place.
    • Insert the plastic opening tool between the white screen backing and the screen to pry the screen backing from the adhesive that holds it in place.
Nicholas Sheffler
408 Reputation
3 Guides authored
Cal Poly, Team S1-G2, Livingston Winter 2018 Member of Cal Poly, Team S1-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G2
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,300
