HP Envy Sleekbook m6-k010dx LCD Replacement
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: step 1, image 1 of 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: step 2, image 1 of 2 HP Envy Sleekbook m6-k010dx LCD Replacement: step 2, image 2 of 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: step 3, image 1 of 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: step 4, image 1 of 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: step 5, image 1 of 2 HP Envy Sleekbook m6-k010dx LCD Replacement: step 5, image 2 of 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: step 6, image 1 of 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: step 6, image 2 of 2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: step 7, image 1 of 1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: step 8, image 1 of 3 HP Envy Sleekbook m6-k010dx LCD Replacement: step 8, image 2 of 3 HP Envy Sleekbook m6-k010dx LCD Replacement: step 8, image 3 of 3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: step 9, image 1 of 2 HP Envy Sleekbook m6-k010dx LCD Replacement: step 9, image 2 of 2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: step 10, image 1 of 2 HP Envy Sleekbook m6-k010dx LCD Replacement: step 10, image 2 of 2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: step 11, image 1 of 1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
2 other people completed this guide.
codi whittaker
508 Reputation
3 Guides authored
USF Tampa, Team S1-G4, Nance Spring 2018 Member of USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 939
