HP Envy Sleekbook m6-k010dx TouchPad Replacement
  1. HP Envy Sleekbook m6-k010dx TouchPad Replacement, Battery: step 1, image 1 of 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 2, image 1 of 2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 2, image 2 of 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 3, image 1 of 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 4, image 1 of 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 5, image 1 of 2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 5, image 2 of 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx TouchPad Replacement, TouchPad: step 6, image 1 of 1
    • Lift the white tab on the ZIF connector to unlock the ribbon cable.
    • Pull the ribbon cable out of the ZIF connector.
  7. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 7, image 1 of 1
    • Remove the seven 3mm Phillips #00 screws from the trackpad.
  8. HP Envy Sleekbook m6-k010dx TouchPad Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to lift the touchpad up and pull out to remove.
codi whittaker
508 Reputation
3 Guides authored
USF Tampa, Team S1-G4, Nance Spring 2018 Member of USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 711
