HP Envy TouchSmart 15 RAM Replacement
  1. HP Envy TouchSmart 15 RAM Replacement, Battery: step 1, image 1 of 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 RAM Replacement: step 2, image 1 of 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 RAM Replacement, Accessory Plate: step 3, image 1 of 2 HP Envy TouchSmart 15 RAM Replacement, Accessory Plate: step 3, image 2 of 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 RAM Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 RAM Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 RAM Replacement: step 4, image 3 of 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 RAM Replacement, RAM: step 5, image 1 of 2 HP Envy TouchSmart 15 RAM Replacement, RAM: step 5, image 2 of 2
    • Hold back the covering to reveal the RAM modules.
  6. HP Envy TouchSmart 15 RAM Replacement: step 6, image 1 of 1
    • Press the clips on the edges of the RAM modules outward to pop them out.
  7. HP Envy TouchSmart 15 RAM Replacement: step 7, image 1 of 3 HP Envy TouchSmart 15 RAM Replacement: step 7, image 2 of 3 HP Envy TouchSmart 15 RAM Replacement: step 7, image 3 of 3
    • You can now remove the RAM modules you need to replace. You can replace the top one, the bottom one, or both if needed.
3 other people completed this guide.
Robert Patterson
1,442 Reputation
5 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2015 Member of USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,663
