HP Envy TouchSmart 15 Wireless Adapter Replacement
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: step 1, image 1 of 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: step 2, image 1 of 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: step 3, image 1 of 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: step 3, image 2 of 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: step 4, image 3 of 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: step 5, image 1 of 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: step 5, image 2 of 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: step 6, image 1 of 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: step 6, image 2 of 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: step 6, image 3 of 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
4 other people completed this guide.
Robert Patterson
1,442 Reputation
5 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2015 Member of USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Members
10 Guides authored
One Comment
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,146
