HP Envy X2-15-C001Dx Audio Board Replacement
  1. HP Envy X2-15-C001Dx Audio Board Replacement, Back Panel: step 1, image 1 of 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Audio Board Replacement: step 2, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 2, image 2 of 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Audio Board Replacement: step 3, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 3, image 2 of 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Audio Board Replacement: step 4, image 1 of 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Audio Board Replacement: step 5, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 5, image 2 of 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Audio Board Replacement: step 6, image 1 of 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Audio Board Replacement: step 7, image 1 of 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Audio Board Replacement: step 8, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 8, image 2 of 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Audio Board Replacement: step 9, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 9, image 2 of 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Audio Board Replacement: step 10, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 10, image 2 of 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Audio Board Replacement, Audio Board: step 11, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement, Audio Board: step 11, image 2 of 2
    • Remove the three 6 mm screws from the audio board using a Phillips #1 screwdriver.
  12. HP Envy X2-15-C001Dx Audio Board Replacement: step 12, image 1 of 2 HP Envy X2-15-C001Dx Audio Board Replacement: step 12, image 2 of 2
    • Flip up the black retaining flap securing the audio board's ribbon cable.
    • Slide the ribbon cable out of its connector on the audio board.
  13. HP Envy X2-15-C001Dx Audio Board Replacement: step 13, image 1 of 1
    • Remove the audio board from the laptop.
Dylan Hathaway
686 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 68
