HP Envy dv6-7363cl Fan Replacement
  1. HP Envy dv6-7363cl Fan Replacement, Battery: step 1, image 1 of 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: step 2, image 1 of 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: step 3, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 3, image 2 of 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: step 4, image 1 of 1
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: step 5, image 1 of 1
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: step 6, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 6, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 6, image 3 of 3
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: step 7, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 7, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 7, image 3 of 3
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: step 8, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 8, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 8, image 3 of 3
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: step 9, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 9, image 2 of 2
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: step 10, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 10, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 10, image 3 of 3
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: step 11, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 11, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 11, image 3 of 3
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: step 12, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 12, image 2 of 2
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: step 13, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 13, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 13, image 3 of 3
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: step 14, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 14, image 2 of 2
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: step 15, image 1 of 1
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
dylananthony
564 Reputation
3 Guides authored
2 Comments
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Reply
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 4,624
